Lift
Old Jun 26, 2012 | 08:09 AM
N_oikion23's Avatar
@chris thanks and also if i do a 3 or 4 inch lift can i run stock tires and 17" rims till the others come in???
Old Jun 26, 2012 | 08:36 AM
ColoJeeper's Avatar
Will look a bit goofy, but won't cause you any problems.
Old Jun 26, 2012 | 09:34 AM
Atch's Avatar
You'll need wheel spacers if you're keeping the factory rims
Old Jun 26, 2012 | 09:40 AM
N_oikion23's Avatar
What size wheel spacers?
Old Jun 26, 2012 | 09:47 AM
snowdog's Avatar
1.5" seems to be the general advice. I'm currently doing exactly what you are planning, until my tires are mounted. and I have had no issues with using 1.5" spacers.
Old Jun 26, 2012 | 10:23 AM
N_oikion23's Avatar
Ok so i need kit wheel spacers front driveshaft pitman arm steering stabilizer anything else?
Old Jun 26, 2012 | 12:06 PM
N_oikion23's Avatar
Afternoon bump
Old Jun 26, 2012 | 12:32 PM
rdubs20's Avatar
rustys 2.5!
Old Jun 26, 2012 | 02:25 PM
Atch's Avatar
Seeing as how you're a 2dr you should probably get a rear drive shaft as well, as far as what else you will need it depends on how complete your lift kit is, you'll need longer sway bar links possibly extended brake lines, and front lower control arms & rear uppers
Old Jun 26, 2012 | 02:31 PM
Incognito's Avatar
@ chris If i wanted to run 35's on a 4inch lift would i need to get a new driveshaft?
Thread jacker!
