which lift?
Old Mar 1, 2013 | 08:26 AM
the_cuse420's Avatar
Default which lift?
What is the best lift to keep the factory feel or make it better? Any info would be helpful with this endeavor
Old Mar 1, 2013 | 09:06 AM
Ryan0260's Avatar
Use the search feature. There are a million threads on here about lifts, and many good options to go with.
Old Mar 1, 2013 | 10:35 AM
Rock Krawler Suspension's Avatar
Former Vendor
We would recommend buying a lift based on your needs! What size tire are you looking to run? Where do you want it to be in the future?
Good luck with your build!
RK
Old Mar 1, 2013 | 11:33 AM
TeraFlex's Avatar
Sponsoring Manufacturer
That would be a budget boost kit that retained the stock coils/shocks to keep the ride the same. However if you add heavy bumpers/etc then you will want coils instead, since factory coils tend to compress with added weight. What size of tire do you want to end up with?
Old Mar 1, 2013 | 12:04 PM
jeepjkgrrl's Avatar
I have a 3.25in lift from Rusty's Offroad and love it. over a year later and still drives great on and offroad.
Old Mar 1, 2013 | 01:51 PM
Muleskinner527's Avatar
I LOVE my Teraflex 2.5" spring lift! With Bushwacker flat fender flares and 35" goodyears the stance is awesome!
Old Mar 1, 2013 | 04:20 PM
Eventually 35s i definitely want a coil lift with just as good of a ride as stock
Old Mar 1, 2013 | 04:45 PM
RKracing's Avatar
Balls To Da Wall Dig Daddy! Go Teraflex 6" Long arm with 37's.......You know you want to go that way in the
long run anyhow........Go For It!
Old Mar 1, 2013 | 05:57 PM
Thanks for the advice. Money is major factor, but in due time
Old Mar 1, 2013 | 06:22 PM
matprovo's Avatar
What is your budget?
