Which lift for 37's?
37's will fit with a 4" lift.
Whatever lift you pick, make sure it has adjustable control arms, and track bars. Anything less isnt enough to dial in your suspension properly. With a 2 door you really need it. In addition you'll need new driveshafts..
4" Fulltraction ultimate will fit your needs
Best would be if you have the money to go with the following
Teraflex Front and Rear adjustable control arms
Evo Coil Over Front
Currie Coils for Rear
JKS Front & Rear Track bars
Crown extended brake Lines
You will have the best setup and you will remember this
Evo Coil Over Front
i have run 37's with a full traction 4" ultimate lift and 1" body lift and i have also run them with a teraflex 4" lift and no additional body lift. both setups work great
Perhaps it's the TJ part of me showing, but it blows my mind that you need new driveshafts just for a 4" lift. Same with the adjustable control arms. It's kinda sickening that you gotta budget an extra $1200 just to go up 4 crummy inches.
on the 4 door you can get away with more lift, not on the 2 door.
Ive got over 5000 miles on my stock drivelines, 4" lift, and 37s with an auto.
All of the 4" lifts are good but some just need more parts added to be great.
I checked into drivelines and they were over $1000. Where can I find a good set for $750-$800?
EDIT: so you know, i double checked and 1310's are in fact about $500 each.
