Lift Comparison
Ok Ive posted Lift questions before, about the ome lift which i fitted to my 2 door rubi, and was not happy with the results so ive gone looking for more lift with other kits, Im looking at The Teraflex 4'' suspension Part Number: 001451400 and Full traction 4" "Premium" Lift System with M-Force Shocks Part Number: FTS7125M which of these is the better of the two kits... Any feedback is welcomed... If possible can i see pics from both lifts. Thanks all once again your help is greatly appreciated
regards David aka(aussiejk)
The ome kit wasn't clearing my 35's as ppl had mentioned it would i had correct back spacing and everything but now i am using the 35's on road 37's off road so more lift required
The only thing SL's do is raise your ride height.
For people who don't really off road, maybe do some fire trails, etc...they may get away with mall crawlers solutions...as they never stuff the tires.
If you actually off road enough to call it off roading....you stuff the tires, and need stuffage room.
As the tires will rise to the same point with or without an SL...if they hit w/o an SL, they'll hit WITH an SL (Unless you've sold your uptravel to the devil, etc...)
Eventually, if you lift high enough, it takes so much to stuff the tires, that larger tires rarely get fully stuffed, and thelonger coils may not let you compress more anyway....so it becomes a Plan B, etc....the stuffage may be rare enough to call it a happy compromise, and live with it, etc.
