lift height question...
Teraflex lift kits seem to run taller than their rated height on the box. At that height I don't think you could go wrong with either direction. The BL route may make it cheaper but I haven't priced out the difference between a 3" and 4" kit.
Think of it like this, buy the 3" kit and the highest you can go is 4" with the BL....buy the 4" kit and you can always add a BL to go 5". Then swap out the whole lift kit for a 6" lift and add back in the 1" BL for 7". Get caught on a rock and wish for more height which leads you to then add in a 1.75" spacer for 8.75". Get bored and swap the 1.75" spacer for a 2.5" BB spacer and now you're sitting in the clouds at 9.5". Forget all of that and swap in some D60s with a SOA leaf set-up and now you're are 14" riding on 54" tractor tires
When will the pockets be empty?
A word of caution about 3" lift plus 1" spacer - when you get a total of 4" lift you will most likely have to add more things to normalize your geometry. 3" kits normally have only springs, shocks and maybe a track bar relocation bracket - it is already pushing the stability of the system. One more inch and you push it over the limit. That's why 4" kits and higher have control arms, track bars and the rest of the junk - the geometry of the suspension changes too much, making the system unstable, and driving, potentially, unsafe. I am not saying this cannot be done, it is just one thing to consider before going this way.
Body lifts can create problems with shifters, steering linkages, etc. Body lifts also tend to stress the body mounts a lot more. Most tend to agree 1" would be the max lift, personally I would skip them altogether.
A 4" suspension lift not only gives the clearance for the tires, it will tend to give you greater articulation and will also have all of the goodies to restore stock geometry to your lifted vehicle. It may be the more expensive route, but you may enjoy the greater capabilities.
Oh, P.S. Why the heck do you call a 5.25" lift a 4" lift kit?!!! lol
