Lift install help--Steering
Old Jul 25, 2009 | 08:37 AM
Ryanc's Avatar
Default Lift install help--Steering
Allright guys, I finally have every thing installed. When I am driving, when I get to 50mph, my steering while does a little shake/vibration, once I get to greater than 55, it goes away. It happens only when I get to 50mph exactly. Tires are set to 32psi, I have NOT done any toe in. On inspection it appears from the factory I have allready 1/8 inch. The jeeps is driving fairly straight, it does not appears to be drifting to either left or right. What should I try first?
Edit: ESP is not firing
Old Jul 25, 2009 | 08:39 AM
whpony96's Avatar
You need to align it (or get it aliened) and have the tires balanced.
Old Jul 25, 2009 | 08:47 AM
Ryanc's Avatar
I had the tires balanced, and did the WOL front end alighnment.
Old Jul 25, 2009 | 08:52 AM
racer83l's Avatar
rotate the tires, see if that does anything.
or if you havent rotated them in a long time.. yet when you did your lift install, you removed all of them then just tossed them back on in different spots may cause that.
Old Jul 25, 2009 | 08:53 AM
Ryanc's Avatar
This is the first they have been driven on.
Old Jul 25, 2009 | 08:57 AM
eDiveBuddy's Avatar
It took the tire place 4 tries to get mine balanced and I only have 33's. The last time they made me come in when a specific person was working. Then they changed from the weights I've seen all my life to these square things that stick to the inside of the wheel.
Old Jul 25, 2009 | 09:04 AM
Ryanc's Avatar
Based upon what I am getting from searching, if you get a shake only at a specific speed it is a wheel balance issue. But keep the suggestions coming because I am no expert at this stuff.
Old Jul 25, 2009 | 09:32 AM
Ryanc's Avatar
Weird, sometimes when I am at 50 it does not do it too bad, maybe it is a wheel balancing issue.
Old Jul 25, 2009 | 11:36 AM
DESERT RAT's Avatar
Just checking but did you remove the retaining clips on your lug nuts ? If so, it's got to be a wheel balance problem.
Old Jul 25, 2009 | 01:36 PM
Ryanc's Avatar
What are retaining clips.
