Lift Installed...Need a answer...
Would someone know what it is...I have a 12 Unlimited Sahara ( Arctic ) edition...I just got
back from a roadtrip ( Carlisle )...I got installed a month ago a Rubicon Express RE7131RXJ kit...
After talking with installer we did NOT install the shocks that came with kit...Keeping in mind i
have the RUBICON shocks installed in my JK...When i hit a medium size bump or crack in road
when my rear tire hits it sounds like i bottom out...I know i's not that...Wouls not installing
shocks do this...I had a 2008 Unlimited JK also with same lift and was not doing that...
Anyone has any ideas possibly what's going on...
There may be an issue with installing the lift but using the stock shocks. The stock shocks may not be long enough for the lift. I don't know what the term is but I guess it would be the opposite of bottoming out.
The sound you hear is the shocks being fully extended when the rear end goes up. Your rubicon shocks are probably better than what came with the kit, just not as long. Shock extenders will take care of it as long as your lift isn't over 2-3".
