lift kit help
Old Feb 9, 2010 | 05:38 AM
tigers34's Avatar
Originally Posted by Stuka
The isolator should not be on top of your spacer. They need to be moved so they are between the spring and the spacers. Otherwise the isolators may not compress the same in that position. Giving you a bit of a lean. You may also feel more vibrations.
According to the instructions it says to install the lift spacer over the stock spring isolator. But again, I'm new to all of this - but having fun learning.
Old Feb 10, 2010 | 03:07 PM
bcboy1969's Avatar
[QUOTE][According to the instructions it says to install the lift spacer over the stock spring isolator. But again, I'm new to all of this - but having fun learning.
/QUOTE]
So that would be spacer on top of isolator which is correct.
