Lift Ordered
Finally ordered my lift and other things I think I needed last night. Here is what I have on the way:
RK 2.5" Flex Kit
RK Front and Rear 3" Bumps
Fox IFP Shocks (4-6" Lift)
TeraFlex Front lower spring retainers
TeraFlex Rear upper and lower spring retainers
RK Rear Coil Correction Wedges
Nemesis Factory Dana 30/44 Front Lower Shock Mount
Adam's 1310 DS with differential pinion yoke and transfercase pinion yoke
I think this should set me up pretty good. I am planning on going with 35's on stock Rubi rims. I already have the spidertrax 1.5" spacers. Is there anything anyone thinks I might be missing? This is for a 2012 2 door Auto
RK 2.5" Flex Kit
The flex kit comes with both of those
JK 2.5 Flex System
These are the shocks recommended if you want :
When running these long shocks for this application we recommend bottom front coil spring retainers and rear coil spring retainers top and bottom. This setup will provide you with a Low COG type build with roughly 1/3 compression - 2/3 droop type system.
I have spoke to a few people running the longer shocks and it gives really good articulation.
Hope that makes sense.
JK 2.5 Flex System
JK 2.5 Flex System
JK 2.5 Flex System
