Lift problems....
Old Apr 5, 2010 | 07:41 PM
i put my new lift on today, and mine is doin the same thing, the wheel is a half turn to the right
but i'm also getting a terrible shimmy/wobble, but it only happens on a bumpy road, or when i hit a bump it gets so bad i have to come to a stop, but when i start off again its fine till i hit another bump
Old Apr 6, 2010 | 01:13 PM
jessmcquaid's Avatar
I recentered my steering wheel after my brother and I installed the lift. Did a 1/2 turn at a time until I did not have to hold my wheel to the left to get it to drive straight. Very easy to get to and adjust.
Old Apr 7, 2010 | 03:48 PM
Jeepincoalminer's Avatar
Re-Centering did fix that problem. I had already done it but I took it a little bit too far to the left when I did it. If you dont get it dead nuts it wont work.
Old Apr 7, 2010 | 04:01 PM
mkjeep's Avatar
Usually takes 2 or 3 tries, test drive , come back, check again. I tie a piece of orange flagging tape to the center of my steering wheel, makes it easier to see when adjusting.
Old Apr 7, 2010 | 04:59 PM
MasterG's Avatar
Originally Posted by codysanders
if you got a procal to change your tire size it will also make centering the stearing wheel a one man job.
How can a Procal help to get the steering centered ? Didn't know that..
Old Apr 7, 2010 | 05:07 PM
mkjeep's Avatar
It has a wheel centering application using your turn signals to let you know which way to turn to center wheel.
Old Apr 7, 2010 | 06:04 PM
MasterG's Avatar
I'm still waiting for the 2010 flashpaqs.. do you know if Superchips have that kind of application ?
( Yes my steering is centered... just wondering... )
Old Apr 7, 2010 | 06:15 PM
mkjeep's Avatar
Dunno, don't have one, I have a procal. Used the orange tape method before I got it.
Old Apr 7, 2010 | 07:23 PM
Weeds's Avatar
Originally Posted by nthinuf
I had the same problem this weekend. Just follow this link. You can recenter the steering wheel with a 15 mm wrench or socket in about 2 minutes.
