i put my new lift on today, and mine is doin the same thing, the wheel is a half turn to the right
but i'm also getting a terrible shimmy/wobble, but it only happens on a bumpy road, or when i hit a bump it gets so bad i have to come to a stop, but when i start off again its fine till i hit another bump |
I recentered my steering wheel after my brother and I installed the lift. Did a 1/2 turn at a time until I did not have to hold my wheel to the left to get it to drive straight. Very easy to get to and adjust.
Re-Centering did fix that problem. I had already done it but I took it a little bit too far to the left when I did it. If you dont get it dead nuts it wont work.
Usually takes 2 or 3 tries, test drive , come back, check again. I tie a piece of orange flagging tape to the center of my steering wheel, makes it easier to see when adjusting.
Originally Posted by codysanders
(Post 1638541)
if you got a procal to change your tire size it will also make centering the stearing wheel a one man job.
How can a Procal help to get the steering centered ? Didn't know that.. |
Originally Posted by MasterG
(Post 1644650)
Originally Posted by mkjeep
(Post 1644666)
It has a wheel centering application using your turn signals to let you know which way to turn to center wheel.
( Yes my steering is centered... just wondering... ) |
(Post 1644753)
I'm still waiting for the 2010 flashpaqs.. do you know if Superchips have that kind of application ? :thinking:
Originally Posted by nthinuf
(Post 1638919)
| All times are GMT -8. The time now is 10:17 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
