Lift question
Old Nov 2, 2011 | 10:47 AM
jjntj2003's Avatar
Default Lift question
Bought a Tera flex 2.5bb from a member it has just spacers and shock extensions. My question is do I need anything else with that small of lift? Don't want to get into dw or any other problems. Local shop said that's all I needed but want to double check.
Old Nov 2, 2011 | 11:01 AM
jjntj2003's Avatar
Will this allow me to clear 285/75-17 on my stock moabs? Don't want to go spacer route.
Old Nov 2, 2011 | 11:03 AM
JGP4JK's Avatar
There are brake line brackets and new rear sway bar links. Is that what you are asking about?
Old Nov 2, 2011 | 11:08 AM
jjntj2003's Avatar
Yes do I need all of that or just what I have. A few said what I have is all I need for that small of lift. Not going rock climbing or real extreme flexing but it will see off road.
Old Nov 2, 2011 | 12:00 PM
ESP123's Avatar
Yes you do need brake line extension brackets for the rear and longer sway bars for the front and rear. Your stock rear sway links are moved to the front with this kit and TF supplies only one set to replace the rear. You also need the rear track bar relocator bracket to get your rear track bar parallel to the axle. I would not go back to the place that said this was a complete kit.
