Lift question
Old May 22, 2009 | 05:35 AM
cunningwolf09jk's Avatar
Default Lift question
I am getting ready to order the aev 3.5" lift kit does anyone know if i can run the stock 17" X wheels without wheel spaces
Old May 22, 2009 | 05:48 AM
robin's Avatar
yes you can, the only problem you would have is if you where changing tires, also sometimes in the rear you have to play with the sway bar links as they get to close to the tire. (put the screw on the inside)
