Lift Questions
Old May 6, 2014 | 12:02 PM
Zane El-Jabsheh's Avatar
Default Lift Questions
Hey guys,
I have a 2011 Jeep Jk 2 door and I'm planning on lifting it. I am on a budget so I plan on getting the best bang for my buck. I really want to do atleast a 3" lift and have the front sit level with the back if not sit a little higher. I have been looking at the Rough Country 3.5" and 3.75" lift. I really don't want more than a 1" body lift.Please let me know what you guys think, I plan on running 35" tires....
2011 Jeep Jk 2 Door O|||||||O Pioneer Double Din Headunit 12" Rockford Fosgate P3 Crunch 1200w amp Spectre cold air intake
Old May 6, 2014 | 12:07 PM
Orangeav's Avatar
if you are starting out on a budget and think you might want to change things up later, I'd look at a lift that is build-able. Rock Krawler, Teraflex, etc. I personally love Metal Cloak. More money, but after 3-4 different set-ups, I'm the most pleased with their springs and control arms. Additionally, don't go for the cheap "quick lift" Save your money and get what you really want opposed to buying on price alone...you'll be happier later!
Old May 6, 2014 | 12:41 PM
Grant09's Avatar
You really don't need any body lift for 35" tires if you're installing at least a 2.5" lift kit.
Old May 6, 2014 | 12:44 PM
Orangeav's Avatar
this is true!
Old May 6, 2014 | 12:47 PM
nthinuf's Avatar
Start with the two threads stuck to the top of this modified area.
As noted, you don't really need a 3+ inch lift for 35.s On a budget, there is nothing at all wrong with just getting a 2.5" BB (spacer lift). Adding a body lift would work if you want more room in the fender wells, but trimming your flares or going to flats might be a better option. If you are stuck on a tall lift, read all of the posts about losing drive shafts and adding/replacing steering components so you have some idea going into it what you might run into.
Old May 7, 2014 | 07:22 PM
What would be my best option for a 2.5" lift with shocks and coils? I got about 400$ to spend...
2011 Jeep Jk 2 Door O|||||||O|Pioneer Double Din Headunit|12" Rockford Fosgate P3|Crunch 1200w amp|Spectre cold air intake
Old May 7, 2014 | 08:00 PM
orangedude71's Avatar
Rubicon 4dr springs and shocks plus rough country budget boost. Cheap and easy
Old May 8, 2014 | 08:04 AM
Rancho's Avatar
Sponsoring Manufacturer
Check out our 2" SPORT system with new shocks and it is on rebate.... BOOM!
Rebate
Rancho Suspension: SPRING PROMOTION
Lift info:
Click on the 2" SPORT
Rancho Suspension: Suspension » 2007 - 2014 Jeep JK Wrangler - 2 & 4 Door 4WD Suspension Systems, Lift Kits, Leveling Systems & Shocks
