The lift that is right for me
Old Apr 29, 2012 | 06:55 PM
powrsurg's Avatar
Default The lift that is right for me
Its time for me to get down to brass tax here. My JKU will be primarily used for daily road driving. I want a rig that will handle the worst of snow storms, the beach, and trail riding. I am NOT going to go Rock Crawling. I demand the same on the road comfort or making it better. I dont want to lift the jeep and be uncomfortable in it.
This being said, I want 35 inch tires and know I need at least 3 in of height.
I have asked the vendors on this board a million questions and they have great in their answers about their products.
In light of my needs,
1) DO I need a system that comes with 8 COntrol Arms? These Systems run between 1600 - 2000 and dont come with skocks.
2) AEV's marketing has me thinking their 3.5in SC lift offers the best ride comfort. (Im a sucker for good marketing) THis comes with SHocks but doesnt use control arms.
3) Would a 3" budget boost system get me where I want to be? These are CHEAP!
RIght now Im looking at the Rock Crawler X Facter, The Full Traction Ultimate, and the AEV SC. After spending tons of money on wheels, another soon to be ton on tires, I would really like to save some money on the lift if possible.
Old Apr 29, 2012 | 06:57 PM
echoshotz's Avatar
A Rock Krawler 2.5 Stock Mod lift or even the 2.5 Flex kit would suffice. I've got the Flex on my dd and it drives fine.
Old Apr 29, 2012 | 07:01 PM
Atch's Avatar
35's and only 5" backspacing you may get some rubbing
Old Apr 29, 2012 | 07:02 PM
mstrofpuppets's Avatar
You can run 35s with 2.5" of lift. This will open your options up a bit. No you don't need all 8 control arms but they do help adjust things back to normal for a better ride. Look at the teraflex 2.5 with shocks also. All of the lifts you are looking at are great lifts and will provide a good on road ride and perform well offroad. My personal favorite is rock krawler, seems like the most complete kit to me. Hope this helps.
Old Apr 29, 2012 | 07:11 PM
Poker5150's Avatar
I have the AEV 2.5 which will fit 35 in tires. I run 33's. I also have the geometry correction brackets and have done the 9/16 bolt mod. The ride is better than stock, firm but very comfortable.
Old Apr 29, 2012 | 07:20 PM
powrsurg's Avatar
Echo, THanks, Ill look into those two. I have not taken delivery of my rig yet otherwise id take a look but does the rubicon come with 8 Control Arms from the factory? Do these budget boost leverage the existing control arms?
The difference between a 4.75 and a 5bs is 6 millimeters. About half of centimeter! I think I can squeeze it in without rubbing in the front and back. I cant wait to put it all together so I can report the results. There was a thread on here recently where a member took pictures of his 12.5 inch wide tires with a 4.75 wheel BS (i think) . There appeared to be tons of room. If Im wrong, Ill add spacers.
Old Apr 29, 2012 | 07:35 PM
thecoz's Avatar
Im no pro but how is 3.75 INCH of BS and 5.0 INCH of BS only 6 Millimeters diffrence?? I came up with 7.65mm Anyways minor diffrences when it comes to fittment WILL make a big diffrence. Also I sugest you look inot RC 2.5 coil kit. You can get a way more complete kit for cheaper than a budget boost. I got mine with adj front track bar, rear track bar bracket, and single SS for cheaper than a bone stock TF kit. You gotta ask yourself are the other brands coils really that much better??? (the answer is NO) plus RC has a lifetime waranty on its coils not sagging so it's a win win
Old Apr 29, 2012 | 07:45 PM
powrsurg's Avatar
For an 18x9 wheel
4.5 BS = -12mm offset
4.75BS = -6mm offset
5 BS = 0 offset.
Mathematically the numbers may be slightly off from what I have above but the manufacturers always market them with those numbers.
Ill check out the RC2.5 coil kit. THanks man!
Old Apr 29, 2012 | 08:36 PM
thecoz's Avatar
For an 18x9 wheel
5 BS = 0 offset.
Yet again I am no pro but I really dont think BS and offset are related. You should do some google research but I believe those are two diffrent measurements. Well good luck on the lift kit I really believe in RC and think you will find some great deals
Old Apr 29, 2012 | 08:38 PM
thecoz's Avatar
Try these:
blog.tirerack.com/blog/eds-tire-guide/wheel-offsetbackspacing
truckinweb.com/tech/suspension/0706tr_wheel_backspace_and_offset/viewall.html]Wheel Backspace & Offset - Truck Wheel Sizes - Truckin' Magazine
