Lift and Steering issues
I installed a teraflex 2.5 inch lift with 1.75 pucks for a total of just over 4" of lift. I've tried centering my steering wheel but it seems to wander a bit. It seems good at times and sometimes it leans to the left or right. Not sure what to do at this point. Is it because I'm over 4" in lift and I have other steering issues? My jeep rides well and doesn't pull in either direction. I'm tempted to pull the pucks and seeing if dropping to 2.5" of lift will help cure things.
Steering is "loose" from loss of caster. With out adjustable control arms it will wander and you will soon destroy the drive shafts. I would remove the spacers or purchase the following-
Drive shafts
Adjustable control arms
Track bars and rear axle end bracket
Steering flip (do not run dropped pitman arm)
Running four inches of lift is expensive.
Drive shafts
I have had a 3.5 spring and picks on my wife's jku for 2 years plus. With NO PROBLEMS. However I did a drop pitman arm and track bar brackets. After center the wheel it drives fine. It's her dd.
Did you do drop pitman arm or brackets? That would be my guess.
I have an adjustable track bar up front and the axle is centered. Track bar relocation bracket in the rear.
Drive shafts
Drive shafts
Thanks,
Tony
