lift suggestions...
Old Oct 26, 2011 | 05:15 PM
joevan29's Avatar
Default lift suggestions...
i've been researching some lifts lately and decided i want to go with a 2in to 3.5in lift and anywhere from 33in to 35in tires. I've only had my jeep for a month and use it as a daily driver. I'm wondering if going with a higher lift and 35in would be bad to drive around town with all the time, I understand i will lose some mpgs by doing this, as well as power. I'm just trying to figure out which way would be best for a daily driver, that I will be hitting trails with.
Old Oct 26, 2011 | 05:21 PM
JEEPNVJK's Avatar
Tons of threads out there-search 33 vs 35 and you'll get some good stuff.
I went with the Teraflex 2.5 on my 2 dr (actually got the 4 dr kit for a bit more lift) and am will be getting 16x8 wheels and Duratrac 315's when my original Rubi's wear down and I have $
do the search-it is worth the time.
Old Oct 26, 2011 | 05:25 PM
Waldo_88's Avatar
ik you said u wanted 2-3.5 inches but im extremely happy with my Pro comp stage 1...it was only about 700 bucks and it does great out on the trails i have 35's and if i do say so myself it looks kickass lower gearing will help with acceleration, mpg, and crawling. do understand with all lift kits the ride is gonna b pretty shitty, the original jk suspension is really soft, new offroad shocks are gonna be rock hard
take it easy, hope it helped
Old Oct 26, 2011 | 05:29 PM
LITTLEredROCK's Avatar
I just had the Rock Krawler 2.5 Max Travel Lift installed and coupled that with Bilstein 5100's - I'm running 35's and the ride now is better than stock.
Old Oct 28, 2011 | 05:03 PM
joevan29's Avatar
Thanks for all the advice I've decided to get a 2in lift with 33s after go through the forums, there is a bunch of useful stuff on here
Old Oct 29, 2011 | 01:12 AM
Kojack's Avatar
I'm running the treaflex 2"/1" leveling kit with 33's. It's just about perfect. I'm installing Hanson bumpers and sliders next year so I may have to Goto the 2.5" performance lift with a mild body lift to get the look I want.
Old Oct 29, 2011 | 03:41 AM
NoFunRich's Avatar
Amen to the info on this site!
Old Oct 29, 2011 | 06:14 AM
Ryan0260's Avatar
Lol. All lifts will ride worse than stock?? This is definitely not true...
Old Oct 29, 2011 | 07:28 AM
Waldo_88's Avatar
Alright alright. I have been proven wrong. Sorry if it mislead you. Ig the cheapie shocks that came with mine are just worse
Old Oct 30, 2011 | 01:41 PM
1FoxyJK's Avatar
I am going to be getting the OME lift for 2-2.75" of lift and if it's on the lower end of the lift then I'm adding 3/4" Daystar spacers up front. If you wanted more lift then you could get the OME HD springs for 3-3.5" of lift, but this lift is mainly for heavy bumpers and winch. I have no winch (nor do I have any plans to get one) so I'm going with the stock springs.
Hope this helps.
