Lift upgrade
Old Dec 10, 2010 | 06:19 AM
rtbksmith's Avatar
Default Lift upgrade
Currently I am running a teraflex 3 inch with front lowers, rear upper control arms, and 35 inch tires. I have a already changed out the front drive shaft for this lift. What on the lift would I need to change to accomidate 37 inch tires.
I would like to avoid a body lift if possible. Thanks for the help.
Old Dec 10, 2010 | 06:20 AM
wayoflife's Avatar
JK-Forum Founder
trim your factory fenders or install a set of flat fenders like the kind bushwacker makes. trim your pinch seam a bit and you should be able to clear 37's
Old Dec 10, 2010 | 07:15 AM
rtbksmith's Avatar
I have the poison spyder front and rear crushers. So, am I able to clear 37 inch tires.
Old Dec 10, 2010 | 07:33 AM
wazooz2424's Avatar
trim the rear pinch seam and then, yes.
or, contact TeraFlex and go to 4" coils. only things you will need that arent listed are track bars.
