Lifted MPG
Old Oct 15, 2007 | 06:43 PM
skissi01's Avatar
Default Lifted MPG
Hey, I have a TJ with 33's and a 5 inch lift kit. I am considering the JK and would immediately replace the tires with 36's or 37's. I'm just trying to do a little comparing between my MPG and yours, PLEASE POST YOUR GEAR RATIO, TIRE SIZE, AND AUTO OR MANUAL. I seem to be getting around 12 MPG. Feedback would be appreciated, thanks guys.
Old Oct 15, 2007 | 06:54 PM
OffTopic's Avatar
2DR or 4DR?
Old Oct 15, 2007 | 07:00 PM
skissi01's Avatar
Everything will be considered, I would just appreciate if the owner posted all specs and everything so I know how he is getting the MPG posted. Thanks
Old Oct 15, 2007 | 07:40 PM
OffTopic's Avatar
Or she?
I'm interested to see what people post too because I just had my lift, gears and tires installed Friday and had it on trails all weekend, and I could swear that my gas mileage actually improved (significantly). But I need to track it this week to get some hard numbers. I do know that it is much higher than the 12 mpg you're getting now.
Mine's an automatic 2DR with the 3" FT Ultimate, 35" tires and 5.13 gears. I had 4.10 gears originally.
Old Oct 16, 2007 | 03:50 AM
mrsig's Avatar
On the highway I am getting about 20 mpg at 70 mph and about 15 mpg in the city with about 10 - 12 mpg off road. The mpg is checked by hand but the computer is a bit off from the tire size. My jeep is a auto. My mpg went up when I added the snorkel too. 6723 miles now.
Old Oct 16, 2007 | 05:41 AM
OffTopic's Avatar
Maybe this is a "stupid girl" question, but isn't the weight of aftermarket bumpers, winch, etc. going to affect mpg also?
Old Oct 16, 2007 | 05:55 AM
Rubidonn's Avatar
Yes... But probably not too much... the main challenge the Jeep has is it's lacking in the areodynamic realm. It's a big brick trying to cut through the wind, so I don't think you'll see much difference w/various tires sizes... from what I've seen, you'll probably loose 2-3 mpg from stock when going to larger tires as long as you regear.
I get around 15mpg city and around 18 highway. This is hand calculated and is +/- 1 in almost every fillup I've had so far.
35's
Auto
5.13's
4dr
Old Oct 16, 2007 | 05:58 AM
CinciAv's Avatar
Unlimited X with Auto and 4.10. Added a TF 2.5 BB and Maxxis 305/70-17 tires (34"). City did not change much, but highway dropped. And yes, I adjusted the post-lift MPG for the increased tire size. OEM tires were the crappy 255/75-17 Goodyear SR-A at 32". Didn't want to go to 35" and have to regear. Highway power is bad enough with the 34"'s!
Pre-Lift (11,500 miles)
Min: 14.5 MPG (City)
Max: 19.7 MPG (HWY)
Avg: 16.6 MPG
Trip Error: 5.6%
Post-Lift (2700 miles)
Min: 14.2 MPG (City)
Max: 16.0 MPG (HWY)
Avg: 15.1 MPG
Trip Error: -4.5% (Not adjusted for the lift)
Seems strange to me that the mileage dropped that much. The final ratio to the pavement with 34"/4.10 is very close to the 32"/3.73 that '08 have now. And the reason for the gear change for the '08 was to increase gas mileage? So reduction in MPG must be a function of increased tire/rim weight and tire width.
Old Oct 16, 2007 | 06:01 AM
wolverine_man's Avatar
I'd be curious to know what people are getting with just a 2" BB and 285 tires (no bigger than 33"). That's basically the setup I will eventually be running.
Old Oct 16, 2007 | 10:30 AM
X2
