Lights came on..
Old Dec 9, 2008 | 07:12 AM
JUS 1 MO's Avatar
Default Lights came on..
Well I finally got my rear trackbar relocation bracket on. We put the Teraflex #1954777 on at my friends house, about 18 miles from mine. We also removed the standard rear relocation bracket mistakenly installed on the front.
After we finsihed I headed home. We forgot to set the steering wheel straight again. I figured I would just adjust that when I got home. About 10 miles away the lights came on and stayed on. How do I get the lights to go off after I recenter the steering wheel?
Old Dec 9, 2008 | 07:23 AM
SuperJK's Avatar
You can disconnect the negative on the battery for a few minutes then reconnect... That should work.
Its what I did when I relocated my evap canister after ripping it off for the second time..
Old Dec 9, 2008 | 10:07 AM
tgrt's Avatar
Former Vendor
The battery thing will work. It'll also go away for a bit if you press the ESP button. And eventually it'll go away entirely if the problem really is corrected.
Old Dec 9, 2008 | 12:20 PM
BlackNorthernJK's Avatar
recenter your steering wheel, problem solved
Old Dec 9, 2008 | 03:14 PM
JUS 1 MO's Avatar
OK guys, that worked.. Thanks to all.........
Old Dec 11, 2008 | 04:56 PM
Good looking out...
