load E vs. load D
Old Aug 30, 2011 | 09:02 AM
mijku's Avatar
I am looking to get new wheels and 35" duratracs tires. I am trying to make up my mind on 16" or 17" wheels. There is not that big of a cost difference between the different size tires but I see the difference in load ratings. Does the load E tires ride softer than the load D? Or should I get the load D for the extra side wall ply and durability? So the size wheel I get will kind of depend on what load rated tire I end up getting. Let's hear your thoughts on the load ratings.
Old Aug 30, 2011 | 09:10 AM
strat_53711's Avatar
You are backwards in your thinking
E rated tires have the harshest ride but sturdier construction.
E rated tires should have more sidewall plys that D.
Old Aug 30, 2011 | 09:12 AM
Dynatrac's Avatar
Sponsoring Manufacturer
E will ride harsher than D. Few tires with 17" wheels are made in anything lower rated than D. The only 37x17" C rated tire that I've seen is a BFG Krawler.
As a rule, a C or D rated tire will flex better and provide better off road traction than an E rated tire.
Old Aug 30, 2011 | 09:19 AM
mijku's Avatar
Your right I typed it backwards. E would be the extra ply and stiffer. Is there a big trade off between the two? Is the ride on a load E that much stiffer? This is my DD and weekend offroad toy.
Old Aug 30, 2011 | 09:28 AM
greenenvey's Avatar
I have trail grapplers that are E rated and I don't think they ride bad at all personally
Old Aug 30, 2011 | 09:35 AM
wayoflife's Avatar
JK-Forum Founder
compared to a C range tire like say, a BFG, an E would be a lot stiffer. however, between a D and E, i don't think it's that much different. the benefits of an E is that the sidewalls are tough as nails. to this day, i have yet to have a single toyo suffer sidewall damage, period. on all the other tires i've run, sidewall damage was always an issue to be concerned with.
Old Aug 30, 2011 | 09:40 AM
cis911's Avatar
I have 37a hankook dynapro Mt with a load range of e this isn't my daily driver but when I drive on the road I have it to 25 psi I don't think it rides rough but I do have to say I have never had tires with a D load rating
Old Aug 30, 2011 | 10:00 AM
Wandell's Avatar
Loved
I have E rated 305/65-17 (33x12.50) BFG AT KO's and they ride fine.
