Lock front or rear?
Ramblings……..
1) It is common practice to upgrade the front of any crawler because of broken parts due to the use/abuse the front end takes.
2) That is until you get to the use of a crawler. As a crawler it is common to have the same size front and rear. As we see in all the “cookie cutter” JKs
. Valid reasons all the way around.
3)Actual question:
I just had you read three boring paragraphs of my thoughts so I can ask this of you while being on the same page as I am. The “front digs” allow for front axle only usage. From just my thoughts this would be extremely handy when it is time to pull yourself up and over a rock without the possibility of an “oh SHIT”. The situation would be from catching traction in the rear at the wrong moment and causing a flip or turnover. Also, limping home with a broken rear diff without having to pull any parts is way cool. After all this am I missing or over stateing advantages of “front digs”????????
. Valid reasons all the way around. 3)Actual question:
2) Crawlers or more aggressive wheelers frequently have equal set ups front and rear diffs. Or are they equal? They're not in many cases. For many people a high pinion 60 fromt and rear is the ultimate for what they do. Are they equal? No. A HP front is stronger than a HP rear because the front is driving on the drive side of the gear while the rear is being driven on the coast side of the gear. Most people choose HP 60s for clearance. In the rear axle, a HP 60 is adequate for a large percentage of users. In the front a HP 60 is usually overkill (for strength) but it is highly desirable due to its DS ground clearance (and in the case of the ProRock 60-or 44- smoother, smaller housing). So why to people go to 60s up front if they're frequently overkill? Axle shaft size. The larger axle shafts are much stronger than even the best 44 shaft.
In the OE 4x4 truck world, axle shaft strength is not nearly as important as housing load carrying capacity. Tire size severely limits the amount of torque the axle shafts will see and few rigs ever spend much time in severe duty low range 4 wheel drive.
3) I love front digs. I use them much more in the woods than the rocks. They allow you to pivot around instead of backing up. In a long rig like an Unlimited they would be an early option for me. You'll also love 2 low. Regardless of locker type, 2 low is much easier on steering in the tight spots. I doubt you'd be able to pull yourself up over a rock as the front would be unloaded and, even locked, you probably wouldn't have enough traction to pull you over.
FWIW- if you break a rear diff you may still have to pull parts. A buddy of mine destroyed his T-case when his rear pinion locked up after a R&P failure. He was in 2 front only and the tires turning the diff caused a major issue and the pinion locked in a very high traction spot. The DS held up, the T-case grenaded.
You have a D30 front - lock the rear.
You are in Texas - go for a detroit. If you want a selectable, get an ARB. If you don't spend a lot of time with tires in the air and want to save a little money, get a TrueTrac.
Or you could add some more info so people aren't guessing about what you want or need or would be best for you...
Totally agree!
