Locker Blinking Light Issue
Seem to be having some locker issues. Not sure what's going on.
Thursday –
Put Jeep into 4 Low
Turned both front and rear lockers on.
Front stayed Lit back would only blink
I could hear a whistle from the rear like there was a rubbing
Turned both off
Took out of 4 low
Rears seemed stuck. Eventually through turning slowly and sharply it became free.
Sunday-
Put Jeep in 4 low
Turned lockers on and was able to get both solid lights though I don’t completely think the rears were locked. I could faintly hear that whistle again.
Turned both off but now the rear locker light stays blinking.
Took out of 4 low
The Rear locker does not seem to be locked as turning is normal however the light has not stopped blinking.
Even after the Jeep has been off for hours, it blinks when the Jeep is started back up.
Sunday Evening-
I tried putting it back into 4 low and engaged the lockers.
I can get the lights solid.
Ive tried a series of forward and reverse with them locked then tried to turn them off but no matter what I do now, the rear light blinks.
Thursday –
Put Jeep into 4 Low
Turned both off
Took out of 4 low
Sunday-
Put Jeep in 4 low
Took out of 4 low
Sunday Evening-
Does it feel like it's still locked?
If not, maybe it has not moved all the way toward unlocked enough to extinguish the light.
Pull the differential fill plug and with a common screwdriver pry the locker to the right and see if the light goes out.
If the sensor is faulty, a condition could be created where the locker is engaged, but since it can't be confirmed, the locker light continues to flash, even though the locker is actually engaged.
It definitely does not feel engaged now but the light is still flashing. I can turn sharp and it does not drag or bounce. I am in drive and the 4wd is off.
I am a little nervous about driving it much in this condition as its my daily driver and I need to work in the morning. I can't imagine them locking as I'm driving at regular speed.
Fortunately the rear was replaced recently as the dealer said they thought they were bad when I had made mention of a noise I could hear from the rear right tire. This was during a 60k maintenance. I know this wasn't the problem and that's confirmed because after they replaced the rear locker, I still hear the noise. I let them do it however because it was under warranty and I figured I was getting a new locker out of the deal.
So needless to say, they will keep getting it back until they fix it right and if it locks and explodes on the freeway, they can pay for all that too. Fricken dealerships!
So the latest is, I brought into the dealership since they are the ones who replaced my "not needing to be replaced" locker.
It took them two days to get a sensor, take apart the rear and replace the sensor. Good news is both my lockers lock right up when engaged and disengage properly.
I think they engage so quickly now because Ive been using them.
Lesson learned -
Use your lockers before you hit the trail to be sure they are working properly and most importantly, engage them regardless at least a couple times a month to keep them moving freely.
Lesson learned -
I can't figure out why the lockers won't engage...push the button once (supposed to be rear lock), push the button again (front lock) and the only thing I get is blinking lights for the locks. Supposed to be 4 dogs in the fight after that but I've got one in the front that will positively turn and one in the back...did they put a Rubicon sticker on my jeep and sold it as such?
Hi Guys
I was hoping someone can help me. I also have an issue with lockers.
My front lockers engage perfectly and light stays illuminated, but rear does not engage and light keeps blinking.
At 10 000km they replaced the diff bearing cauase it was making a huge noise at low speed.
Now at 44 000km my diff lock is not working, but i do not know how long it has not been working, cause you don't always need to use it!
The dealership is saying i knocked my diff housing and "warped" the housing. And saying there is something wrong with the jeep cause my rear right shock spring is not straight.
I can't see how that effects the diff lock.
The report says that when they opened the diff cover they found a shim has come out of place. They put it back in place, but diff lock still not working.
they charged me for oil replacement, but still can't tell me why the diff lock is not working.
Their solution is to claim a whole new diff housing using my short term insurance because they say it is not covered by my warranty, our warranty in SA expires at 100 000km. Ridiculous!
Can anyone help me out any suggestoins i can try? Could it be faulty sensors? Faulty acuator? Anything???
Attached are pics of my diff cover open. if anyone can see anything out of ordinary please share.
Thank you.
Thank you.
