Locker position sensor?
Old Jun 6, 2012 | 06:04 PM
pontiac31's Avatar
Default Locker position sensor?
Installed my pro rock about a month ago. My gear installer didn't put the sensor in until after the carrier was installed. I pulled the sensor so I could drive it til I could fix it.
I stripped a few threads off the end so I could get it in on an angle, hooked the plunger, tried it with the cover off, and presto everything works great.
Until I drive to work this morning. In 2wd at a stop the dash light is off, as soon as start to move the light blinks???
Any ideas what this could be, I know for a fact it is not locked, and when put in 4lo the locker works fine and the light stays on.
Old Jun 6, 2012 | 06:12 PM
ronjenx's Avatar
Does it continue to blink when you are in 2wd, and 4wd unlocked?
If so, it is probably stuck in the extended position.
It could also be a short in the wires leading to it.
Old Jun 7, 2012 | 04:57 AM
pontiac31's Avatar
I have not tried 4wd with it unlocked, it does continue to blink in 2wd. On occasion it will stop for a while when moving, and always turns off when the Jeep is stopped in 2wd.
