Locker questions HELp
Old Oct 2, 2013 | 09:33 PM
deepjeep13's Avatar
Default Locker questions HELp
M waiting to lift my jeep in the spring but i figure why not add a locker in there... My question is do i need 2 front and rear or just the front? I have a 2013 sahara and from what ive seen the rear end locks up ... Please help
Old Oct 2, 2013 | 09:55 PM
BRUT4CE's Avatar
Former Member
I'd go rear first for most stuff weight on rocks and climbs is back so it has pressure down versus front sliding....if given the opportunity go both there's been times when even both lockers and 6psi in the tires'wouldnt get me through....lol but the lockers got me there and it was fun....
You don't have to do both....search and find out what your use would dictate as a better choice for you...
Old Oct 2, 2013 | 10:14 PM
Jaydy's Avatar
If you plan on doing lots of mud id recomend the rear because u dont want to be steering to much with the front lockers on. Id vote for both
Old Oct 2, 2013 | 10:17 PM
deepjeep13's Avatar
Originally Posted by BRUT4CE
I'd go rear first for most stuff weight on rocks and climbs is back so it has pressure down versus front sliding....if given the opportunity go both there's been times when even both lockers and 6psi in the tires'wouldnt get me through....lol but the lockers got me there and it was fun.... You don't have to do both....search and find out what your use would dictate as a better choice for you...
Here in manitoba we for either nasty muck or sand... When i went wheelin last time i got stuck in nasty clay and my rear end locked and almost snugged me out but my front end burried on the one side wouldnt let me out.. Im thinking if i could get a rubicon locker id be happy with the push button but at the moment im looking at the ARB 373 locker
Old Oct 2, 2013 | 10:24 PM
BRUT4CE's Avatar
Former Member
I've run, Detroit locker, true track, factory, ARB, Eaton e-locker and they are all good...I actually love my rubicons lockers....
Cant go wrong with any of them they are all good choices....
Old Oct 2, 2013 | 10:49 PM
deepjeep13's Avatar
I've run, Detroit locker, true track, factory, ARB, Eaton e-locker and they are all good...I actually love my rubicons lockers.... Cant go wrong with any of them they are all good choices....
I seen a black ops jeep with only a front locker. Im hunting ebay to see what i can find
Old Oct 3, 2013 | 12:18 AM
nthinuf's Avatar
So you have a rear factory limited? With clutches? That wear out?
Do you need a locker? Or just feel like spending some money? If you don't crawl, a pair of TrueTracs may be pretty hard to beat! If you want lockers and only do one, rear gets my vote. Though replacing the front spiders may not be a bad idea... (Personally, I would not dump a grand, plus labor, into a front d30 selectable. Truetrac or lunchbox, then throw it away when it breaks.)
The folks at Dynatrac posted a decent overview a while back:
Project-JK.com - Jeep JK Wrangler Resource » Dynatrac Presents - Lockers 101
Old Oct 3, 2013 | 09:48 AM
deepjeep13's Avatar
Originally Posted by nthinuf
So you have a rear factory limited? With clutches? That wear out? Do you need a locker? Or just feel like spending some money? If you don't crawl, a pair of TrueTracs may be pretty hard to beat! If you want lockers and only do one, rear gets my vote. Though replacing the front spiders may not be a bad idea... (Personally, I would not dump a grand, plus labor, into a front d30 selectable. Truetrac or lunchbox, then throw it away when it breaks.) The folks at Dynatrac posted a decent overview a while back: Project-JK.com - Jeep JK Wrangler Resource » Dynatrac Presents - Lockers 101
I think it would be a good step forward. I was shocked how guys with lockers were just plowing threw everything and i just figured down the road it would be a good idea.. A grand sure is alot but my lift alone is $1300. I just wanted to do it right te first time around is all
Old Oct 3, 2013 | 10:25 AM
filthy-Beast's Avatar
If doing lockers also think about your gears, it's much cheaper to pay to do them together. Yes lockers have an advantage, but also bring more stress to your stock front axles. the below happened with the front locked, trying to climb a curved trail up a rutted muddy hill, slipped off a ridge into the rut with the wheels turned slightly and got instant traction, causing "pop-goes-the-weasel".[HR][/HR]
Old Oct 3, 2013 | 12:04 PM
deepjeep13's Avatar
Okay now im worried lol
