lockers?
ok guys.. i have read, read, and read some more.. and im obviously not a retard(most of the time) but i am still curious about some locker issues.. i have a JK and im looking for a cost effective (college budget lol) locker.. is there a locker out there that engages without air?.. i dont really have time or money to drop in compessors and what else goes along with them.. i just want something to lock the rear end together when i go wheelin.. i dont need a front end lock right now because i dont wheel enough hardcore to get one.. yet.. any help is great.. thanks guys..
http://www.teraflex.biz/
Lunchbox replaces the spider gears in your open carrier. A Detroit replaces the entire carrier itself. They both work very similar in being locked 100% of the time under load and can unlock when load is not present.
I'm personally going Detroits front and rear.
On a budget and looking for improved traction via possible locker? Why not consider a lunchbox as mentioned above in the front? That will improve your offroad traction alot, plus very budget minded.
A cheaper alternative to those expensive lockers is also an Auburn Ected if your really wanted to get locked in the rear. Uses an electro maget to actuate, just hook it up to your electrical and engage when needed....only draw back is it is a clutch style system which will one day wear out....I just don't know when
It isnt that bad to install....you will need to drill out the ring gear mounting holes to half inch in order to be able to mount the ring gear to it, for that you will need a nice half inch drill bit and a drill press.....from there it just requies that your able to pull your old carrier assembly out, swap the gear and bearings and throw the new unit in...if your just doing the unit swap then there should be absolutely no requirement to adjust shims or anything providing you put the shims back in the appropriate spot, the mesh between ring and pinion should remain unchanged. You will just need basic tools and either new carrier bearings, or the ability to pull your old ones off and press them onto the new one...if you dont have a press or bearing splitter, a driveline shop should be kind enough to help you out on that small part I would hope
https://www.jk-forum.com/forums/modified-jk-tech-2/begins-78112/
