Lockers, Axle Upgrade and gears
Old Jul 21, 2007 | 02:17 PM
unimog2's Avatar
Default Lockers, Axle Upgrade and gears
Looking into regearing my 07 X w/6sp Man from 4:10 to 4:88 or 5:13's. Currently running 3"BD lift with 35" Procomp MT's. Been reading about the D30's braking a bit with the 35's (Daily driver with occassional wheeling fun w/jeep club).
1. I want to put in ARB air lockers in so do I need to upgrade the front axle to a super 30 kit or ?
2. Being a daily driver, I think the 4:88's will be better, does anyone have any experiece either way?
I would love to put in a D44 but that is a lot of $$$.
Thoughts, experiences, good technical data much appreciated.
Cheers
Mike
Old Jul 21, 2007 | 07:11 PM
ZachMan's Avatar
With the JK extra weigh I'd go 5.13s, even thoughit makes the d30 even weaker. ARB or an OX is a good choice. The "super 30" kit won't work with your JK d30, nothing is avalible yet, plus its going to usually be the u-joints that break. 35s are the very limit to any d30.
Old Jul 22, 2007 | 07:57 AM
Maxcustody's Avatar
Why does changing the gears to 5.13 make the D30 even weaker?
Old Jul 22, 2007 | 08:55 AM
Renegade's Avatar
Fewer teeth on the pinion gear to maintain the low ration. Larger diameter gearsets will have more teeth on the ring, and in-turn more on the pinion + the gear surfaces are wider and maintain the same ratio. More teeth on the pinion gear = more surface area in contact = stronger.
Old Jul 22, 2007 | 09:01 AM
Maxcustody's Avatar
So 5.13's have fewer teeth therefore less suface= weaker? Is that right?
Old Jul 22, 2007 | 10:11 AM
Renegade's Avatar
In theory, yes. It will also depend on the "pitch" of the teeth. Here are soe tooth count numbers for the Dana 44 for comparison:
Ratio Teeth (ring gear/pinion gear)
3.07 43-14
3.23 42-13
3.31 43-13
3.42 41-12
3.54 46-13
3.73 41-11
3.92 47-12
4.09 45-11
4.10 41-10
4.27 47-11
4.56 50-11
4.88 44-9
5.13 41-8
5.38 43-8
Old Jul 22, 2007 | 12:54 PM
unimog2's Avatar
Appreciate the feedback. Still debating on the lockers. Much $$ for minimal use, but damn, it would be nice to have (look fellas an air compressor, pssst, pssst, locked unlocked).
Old Jul 22, 2007 | 02:47 PM
tjdUSCG's Avatar
dropping that much money on an ARB and gears might make it worth it to go to a dealership and get a price on a Rubicon spec D44. You might be surprised. And I'm sure there's some ranger/tacoma/S-10 driver out there on ebay who's looking for a solid axle to swap into their vehicle if you needed to gt rid of a D30 after replacing it.
Old Jul 22, 2007 | 03:38 PM
Renegade's Avatar
Originally Posted by tjdUSCG
...might make it worth it to go to a dealership and get a price on a Rubicon spec D44. You might be surprised. And I'm sure there's some ranger/tacoma/S-10 driver out there on ebay who's looking for a solid axle to swap into their vehicle if you needed to gt rid of a D30 after replacing it.
You should be able to find one for less than $1400. You can then sell or part-out the 30. THat's what I am doing. According to the computer my 44 should be here tomorrow...we will see.
Old Jul 23, 2007 | 02:56 AM
AddictedToJeeps's Avatar
I have 37s with 5.13 gears and auburn lockers front and rear on my X. It has a dana 30 in the front and a 44 in the rear. I wheel blacks all day long and this setup seems to work great for me. Plus i drive this jeep everywhere and it runs and drives great.
