Lockers or Tires
Ok so right now i have a 07 jk x with 3in lift and 285/75/16 ssr which come out 33.5 in diameter they are good tires and do what i want but i wish i had gone bigger and i am torn between wanting bigger tires like 36s or should i lock up the jeep front and rear first by the way live in louisiana so i mostly wheel in mud
My thought would be go with the tires first learn to wheel it open front and rear. Once you get good like that then look at the lockers. But for mud I would look at only locking the rear so that way you can still turn. Plus a locker in the front on a D30 you need/should upgrade your axles and everything along with it. IMO.
Thats i want is tires but i fear if i go to 36 or 37s than i am looking at having to have hydrualic steering or not i am asking. And also i thought lockers would aid with traction in mud more than tires not sure though
. Although thats i was posted is to get everybody else opinions cause i am not sure and i will try not get to stuck but thats why i bought a jeep
Get an idea of what the lift requirements will be when moving up to a 37" tire. Which components will you want? Which components will you have to have? Check into backspace and rubbing issues. Take a good look at your axles. How will you strengthen that little D30 to handle those tires when spinning through the mud? Are you planning to run 37's with your stock gears? Not likely, so look at your gearing options. (this is the time to decide on lockers. Have them installed together instead of paying that labor twice)
Do yourself a huge favor - take a step back, look at the big picture of not only what you want to accomplish, but what the best way to get there is...
tires will take you further than lockers. one thing alot of people forget in mud is lockers are completely useless if you do not have traction first
someone said earlier, see what your lift is capable of. your lift may not even be able to handle 37s without other modifications to suspension or cutting. if you have 4.10 gears, it wont be too bad with 36s or 37s but if you have numericaly lower gears, then its just going to suck with bigger tires. i ran 37s on 4.10 for a bit first then upgraded gearing and lockers at the same time.
if you have below the 4.10 gearing, i would stick with the tires you have and invest in a winch and a pull pall or buddy(whatever its called) untill you can afford to buy tires, gears, and lockers about the same time. if possible its financially smarter to install gears and lockers at the same time
just take the time to scrimp and save untill you can afford it. i know it sucks cause we all get the "itch" but sometimes you should stop and think and wait.
this is my opinion, some people may agree or disagree, but its your money, your jeep, you do what you want. hope this helps
