LoD JK Rear Bumper Tire Carrier - Finished & Installed Pics
JK-Forum Founder
Just updated the original post to include a few pics of the trail rack and jerry can mounts installed. Click on the link below to see them...
https://www.jk-forum.com/forums/show...43&postcount=1
Wow. That looks really good.
Now, that's basically the finished product, the final design?
Are those problems you ran into going to change the overall look of it?
forgive the newbness, but what exactly is the purpose of the bumper with tire carrier over the stock bumper/spare mount system?
edit:
also, how does this affect the prospect of adding a bicycle carrier? is opening the cargo area door affected?
edit:
JK-Forum Founder
Do they plan on selling just the rear bumper without the holes for those of us not needing the tire carrier? I just ordered the front bumper about 2 days ago and would love to get the matching rear
JK-Forum Founder
Honestly, I don't know. Ususally the question that has been asked in the past is, "can I upgrade in the future if I don't buy the trail rack and jerry can mounts now?" I'll talk to LoD about it but if it were me, I'd keep the holes just in case and then for now, I would just buy some plastic 3/8" round plastic plugs, apply a bit of black RTV to them and pop them in the holes. You now have a water tight A-Frame and the option to upgrade in the future
Are there any mounts for a hi-lift, shovel, axe, and/or pick?
It certainly looks great, although I'm going to wait and see what Garvin comes up with. Their expedition roof rack will be a must for me...
js.
js.
When you start running a larger tire size like a 35"-37", the added weight will most likely be too much for the factory spare tire mount and/or the tail gate to handle without eventually causing a break. By using a bumper tire carrier, you are now transfering the weight of the large spare tire onto your frame which is much stronger.
Opening up the cargo area is not affected with the LoD rear bumper tire carrier and, as far as a bicycle carrier goes, it should be affected at all as the spare tire ultimately sits about the same distance from the tail gate as before and if anything, higher as well.
