LoD Rear Bumper and HiLift Jack
Old Apr 29, 2009 | 07:04 AM
SnakeDriver's Avatar
as mentioned, the brackets attach to the side of the tire-carrier frame and are used to push up against the factory rubber isolators. the hi-lift attaches on top of the frame.
Do you have a picture of your tire carrier that illustrates the brackets and the hi-lift for the mechanically challenged???
Old Apr 29, 2009 | 07:38 AM
wayoflife's Avatar
JK-Forum Founder
here's a close up shot with the tire carrier slightly opened....
when closed, the bracket will push on the isolator and squash it down.
Old Apr 29, 2009 | 07:41 AM
You rock, Eddie. Thank you, sir.
Old Apr 29, 2009 | 02:11 PM
funtimes's Avatar
I love this carrier and bumper.....Looking at buying one.....Is the install on one of these pretty easy?? I read in past threads that the directions kind of sucked. Have they redone them to make it a fairly easy install??? Thanks
Old Apr 29, 2009 | 02:16 PM
Funtimes -
I was a piece of cake to install. Did it all with handtools in the driveway. Hardest part was lifting it into place by myself. Used a floor jack to get it "near" position, and then muscled it into place.
Old Aug 9, 2009 | 09:04 AM
Muffins's Avatar
Just installed mine this weekend, wasn't bad at all, one of the holes needed to be opened up a tad on the bumper and I had to purchase grade 8 hardware but it does look great and the tire carrier is good too.
One question I did have is torque specs. I tightened the factory bolts in the frame to 50 ft-lbs. The ones behind the hitch inside the bumper I tightened to 40 and the rest that go all the way through the cross member and frame I tightened to 35ft-lbs. I would have gone farther but the holes the washers rest against are large and I started to deform the cross member and washers so I didn't want to push it. I figure if the steel is deforming it is tight enough, not to mention there are 12 grade 8 bolts holding this thing in place. I hope those torque specs are sufficient for light towing and an occasional recovery. The other option is to weld it like one of the members on here did
I know, I worry too much.
Old Aug 9, 2009 | 11:58 AM
Ryanc's Avatar
I was wondering about torque specs also.
