Lod silder question
Old May 8, 2011 | 05:45 PM
DCJEEP's Avatar
Default Lod silder question
Trying to install my sliders and it says they should be straight. But it seems they slope towards the rear of the vehicle. Someone help ASAP. Or is that how they were.
Old May 8, 2011 | 06:33 PM
wildandwillin's Avatar
Mine sit straight
Old May 8, 2011 | 06:59 PM
DCJEEP's Avatar
Originally Posted by wildandwillin
Mine sit straight
Weird. I'll have to screw with them some more next weekend. Did you have ton add washers to make the straight or did they bolt up straight?
Old May 8, 2011 | 07:00 PM
Merlin4979's Avatar
There should have been some thick spacers to use to balance everything out in hardware kit. Did you use that? (Looks like a giant washer)
Old May 8, 2011 | 07:51 PM
I used washers to level it out before my lift. Know I actually have a long arm lift that would not allow use of the designed install. So I cut and welded to the frame.
Old May 8, 2011 | 08:26 PM
DCJEEP's Avatar
Hmm I bought em used and didn't get the washers.
Old May 8, 2011 | 08:45 PM
wayoflife's Avatar
JK-Forum Founder
they will sit differently depending on whether or not you have them mounting above or below the skid plate mounts on the frame rails.
Old May 8, 2011 | 09:30 PM
Very good I forgot about that
