LOD sliders????
Old Oct 25, 2013 | 05:18 AM
mstrofpuppets's Avatar
Default LOD sliders????
Has anyone had any problems with the bolts stripping out or coming loose from the frame since they are drilled and tapped? I am making my own sliders and was curious if drilling and tapping the mounting holes was a good way to mount them to the frame. Thanks!
Old Oct 25, 2013 | 06:10 AM
mattgt5's Avatar
I've ran them on three jks and never had an issue. I think its a solid mounting solution.
Old Oct 25, 2013 | 06:23 AM
Lusky's Avatar
I only bolted up thru the existing holes plus welded on.
Old Oct 25, 2013 | 06:44 AM
mattgt5's Avatar
I have decided that I was going to do this the next time I install these. Drilling these holes is a bitch
Old Oct 25, 2013 | 06:50 AM
How much of the mounting plate did you weld? On all sides?
