Long arms & adj short arms
Old Jun 8, 2012 | 06:40 AM
Powderburn's Avatar
Default Long arms & adj short arms
Long arm upgrade "kits" are pricy. Iv been doing a lot of reading and if I am correct, the front lowers and rear uppers (the shorter arms that you dont have to weld new brackets for) are pretty much adj short arms. So...... Couldn't you just buy them separate and it be a little cheaper?
Old Jun 8, 2012 | 06:45 AM
wayoflife's Avatar
JK-Forum Founder
not all long arm kits are made the same but, for ones that are made right, you would have to cut off and relocate ALL your control arm frame mounts and replace them with new ones that relocate them further back.
Old Jun 8, 2012 | 07:06 AM
Powderburn's Avatar
I really like the RK long arm upgrade but From the picture it shows it looks like its missing 1 or 2 shorter arms. Am i seeing it wrong?
Old Jun 8, 2012 | 07:07 AM
Redman333's Avatar
Is there a major improvement to having the weld in long arm or the bolt in long arm?
Old Jun 8, 2012 | 07:23 AM
wayoflife's Avatar
JK-Forum Founder
you are seeing it right, they use a single upper control arm design. most long arm kits utilize 2.
there is no difference between weld on or bolt on other than the fact that with one, you need to check your bolts from time to time.
Old Jun 8, 2012 | 07:35 AM
jeepnsam's Avatar
i wouldnt think so... i would like to know also!^
Old Jun 8, 2012 | 07:53 AM
charest2394's Avatar
Would it be possible to have company names that are long arm setup no solder to the frame please.
Thank you!
Old Jun 8, 2012 | 08:06 AM
wayoflife's Avatar
JK-Forum Founder
Thank you!
evo mfg makes their double d kit and full-traction makes one too.
Old Jun 8, 2012 | 08:09 AM
BuckLisa's Avatar
Clayton's new Long Arm is either bolt on or weld on.
Old Jun 8, 2012 | 08:11 AM
wayoflife's Avatar
JK-Forum Founder
so is the evo double d - if you think about it, ALL bolt on kits can be welded on
