Long or Sort Arms on JKU?
So has anyone run both or decided one or the other for any reason? Im new to JKs and noticed that the factory arms are a hell of a lot longer then my old XJ and ZJ arms. Is it really benificial to run long arms on a JK? I plan on running 4 inches of lift with 35s or 37s. It will be my DD but I run the Con, Moab and its not a trailer queen. It will get wheeled hard though. Does anyone have regrets with a set up now?
We are running Rock Krawler's 2.5" X Factor Plus Mid Arm Kit. This kit flexes great. Check out these pictures of us checking it with the fork lift.
Fork Lift #1
Fork Lift #2
It also handles obstacles pretty well considering its only a 2.5" lift sitting on 33's, but we will be going to 35's once we re-gear it.
Rausch Creek 12/22/12 | Facebook
The kit was also pretty much bolt on. It does require lots of welding for the 3-Link Mount however it still isn't nearly as much welding as the long arm kit would require.
If you didn't go with the 3-Link in the rear then the only welding required is when moving up the rear shock mounts (if you choose to, which is a great idea), and welding the rear track bar mount in place. This step isn't required but based on the description of the wheeling you will be doing we highly recommend you weld the new mount in place.
If the fabrication and welding aspect of the installation does not bother you at all then yes a long arm kit is the better option. You will receive additional flex.
Fork Lift #1
Fork Lift #2
I noticed JKs with 4 inch or so lifts still have relatively level control arms which is nice. That retains highway smoothness and keeps the tires at the beginning of the arc when it flexes. Really the only reason I'd get long arms is because they redesign the angles to achieve better performance through anti dive, anti squat and roll center changes. One thing about a JKU is the long wheel base and maximizing clearance. If I decide a short arm route I'll probably go with something like the Currie set up with 8 new arms. Long arms I'm not worried about installing because I'm a mechanic and have the resources but the price difference could be sliders and other armor. I agree, I think long arms are a thing for TJs or hard core JKs. I wheel hard but ultimately it's my DD also.
I'll wait for more opinions before I decide which route to go. Thanks!
