Lost height due to new bumpers
I was looking to run a Teraflex 2.5" coil suspenion lift (with shock adaptors - given that I have a brand new Rubi) so I can run 35s. After doing some reading, I guess I'm an idiot, but I didn't consider any height I might lose when I add a new front bumper/winch and a new rear bumper w/ tire carrier. I am thining something equivalent to ARB, front and back. So...
How much height will I lose from new front and rear? Also, what is the total weight I will add? I know it will depend on what exactly I get, but assume it is nothing "crazy." Thanks!
I have the same lift but with Bilstien 5100 shocks and I was surprised when I did not lose any height when I installed my LOD front bumper. I haven't measured since I put on the Skid Row engine skid this weekend and am curious if it impacted the lift as well.
I hope to have the LoD Rear bumper and tire carrier on this month or next so I can't speak for the rear yet
A couple thoughts that might help (or might not) ...
1. I believe that the TF 2.5" coil lift for the four doors had a change in springs when folks were getting a lot more height than anticipated. So, folks with the earlier set-up will have different experiences than folks with the later set-ups and their comments here will reflect that.
2. While I don't know what adding my aftermarket gear (see signature) would have done to the 2.5" TF coil lift because that gear was already installed when I did the lift, I do know how much more I gained over a 2.5" budget boost and stock springs (bear in mind this is a four door, and one of the later TF lifts): 3/4" in the front and 3/8" in the rear. So, I can assure you that there is some compensation going on for the additional weight (which was why I added the lift in the first place).
After installing my lift, bumpers, winch, etc. I wanted more rake so I added 3/4" spacer in the rear. Installed them 2 days after I ordered them.
Spacers are usually kept in stock and are fast to install. It's not like you'll be waiting weeks if your are unhappy.
