Loud creeks, squeaks and knocks
Old Mar 9, 2011 | 09:54 PM
Default Loud creeks, squeaks and knocks
I have a 3.5 rubi lift. Everything has been retightened twice. Loud squeaks when goin over bumps or driving.. And when turning steering it sounds like knocking...
Any ideas? I've retightened everything to specs
Old Mar 9, 2011 | 10:56 PM
nvrenuff's Avatar
Did you torque control arm bolts with jeep under its own weight? Don't torque bolts with jeep on jacks or lift. Knocking while turning, are you in four wheel drive when it does this? If so it might be axle ujoints talking to you. Is it knocking or more like popping or snapping? If it's knocking can't think but somethings loose.
Old Mar 9, 2011 | 10:58 PM
No not in 4WD. More like when parking or backing out of a parking space.
Old Mar 9, 2011 | 11:16 PM
nvrenuff's Avatar
If everything checks out, check tires rubbing on control arms, bumpers etc. If you have aggressive mud tires could be tire lugs rubbing making knocking, but I wouldn't really call it knocking.
Old Mar 10, 2011 | 04:31 AM
GON WHLN's Avatar
I'm having the same pop sound in the rear when I back out and turn from a stop.
I kee[ thinking its my springs moving around since they won't stay put when I check em. Ordered spring clips and stays. Maybe this will help.
Old Mar 12, 2011 | 10:33 AM
Thanks it was the control arm bolts :-)
