Loud metallic 'SKRONK!' sound when offroading
When I go off road I sometimes get a loud, harsh metallic noise, very sharp and short like SKRONK! underneath. I even noticed it today while in 4-low and backing up and turning, but generally it happens every now and then when in 4-low and going over rough terrain at low speeds (nothing extreme like rock crawling though). I guess I'll take it back to the dealer as they installed the Mopar 2" lift, but any clues what this could be?
I had the lift installed almost from the start, so it may not necessarily be the cause - I just never off roaded the rig before the lift. It's a 2-door 2010 with only 3K miles. Does anybody else get a sound like this offloading?
Here's a lousy cell phone pic of my rig:
I get what i think is the same noise when i go over speedbumps, not sure if that happens to you or not
Try checking out
https://www.jk-forum.com/forums/show...nd-noise-(long)
Maybe it might have some useful info for you
Edit: Double read your post and realized you said its when your in 4low..
Do you only hear the sound when turning? and in 4lo?
Try checking out
Try checking out
Try checking out
Do you have a lift, too? I am wondering if it is the springs rotating or moving...
It's got factory wheels, just the 32" ones. I don't think I have the wheels turned very far when the sound happens...
Try checking out
Try checking out
I got the same sound to when I go on 4lo everything is tight under the jeep I just put my new suspension and it still doing the same sound... firts time I was tought its was a bering wheel but after reflex It just happen after putting 4lo so I guess is in the front axle bering an pinion or maybe transfer case cause in 2wd no sound everything work good cause if you dont have a rubicon like me your front wheel lock only in 4lo maybe its the locker or that thing im not a expert
The backing plate behind the brake rotors loves to pick up rocks, which then make a high pitched metallic noise. If you can put up with it, usually will fix itself. I wouldnt describe it as a skronk, however.
It is a short, sharp, metallic screech, metal on metal?
Mine does that sometimes hitting something like a sudden bump, but only once in a while. Has happened since 09 after the engine conversion.
I have never pinpointed it. Everything is tight and the suspension works fine, steering is stable at 80 mph. I always figured it might be the exhaust system since that was changed, hangers or heat shields, shifting (jumping) on the bump. It is for sure metal against metal movement though.
My noise is not related to 4-lo, can happen in 2wd.
