Loud Squeeking while driving.
Old Aug 21, 2008 | 11:31 AM
northsidejeepin's Avatar
Default Loud Squeeking while driving.
I just installed a 5.5 inch BDS LA kit, and after a hard weekend of wheeling, I am getting a loud metal on metal squeeking when I accelerate. It does not happen while in reverse, and seems to get quiter when I am up and going. Mostly noticeable under initial take off. It also feels like there is a slight vibration when taking off, but goes away once moving.
Does anybody have any idea what this may be? Drive shafts look good, and so do the brakes. I was thinking maybe wheel bearing, is this possible, whatare the symptoms I should look for?
Thanks!
Old Aug 22, 2008 | 08:07 AM
There is also a little bit of a shaking in the steering wheel when taking off.
Old Aug 22, 2008 | 08:10 AM
Piginajeep's Avatar
Did you look at your driveshaft boot?
Old Aug 22, 2008 | 08:11 AM
No, but I will do that right now. Would it sound like metal on metal? Is the boot the part that the drive shaft touches first sort of like a surrounding ring?
Thanks for the help!
Old Aug 22, 2008 | 08:12 AM
Piginajeep's Avatar
If you have stock driveshafts, yes. it sounds like your bearings are shot...
look for this
Old Aug 22, 2008 | 08:15 AM
No, I have woods shafts, and no rubber boot, but it does sound like shot bearings, but I have 6K miles and I don't think they are dead yet, or could they be?
Old Aug 22, 2008 | 08:19 AM
Piginajeep's Avatar
OK, I was assuming you had stock shafts... Um...
Old Aug 22, 2008 | 08:21 AM
It does not make the noise in reverse either, which is why I am so confused and have no idea where to look, unless i take the whole wheel assembly apart.
Old Aug 22, 2008 | 08:34 AM
jonsjeep's Avatar
check your shock hardware. i had the same noise and it went away after making sure the shocks bolts were tight enough. even a little play will make those things squeek like crazy
Old Aug 22, 2008 | 08:39 AM
Ok will do!
Thanks for chiming in!
