Low-cost / Free mods that should be done?
#2402
#2403
#2405
If you run a soft top in the summer be sure whatever you do is secure in case of an accident. You (or I) don't want that shovel flying around.
That is a perfect shovel. Does it have a brand name on it-I like the black and gold color too.
#2406
front hockey puck bump stops
needed 2" worth of bump stops in the front, $8 worth of hockey pucks and $2 worth of adhesive
1 jack up jeep by frame so you have enough space to slip in puck
2 put adhesive on lower mounting surface (not on puck you will make a mess slipping it through the coil)
3 slide puck in
4 repeat for desired hight
10 min job
3 slide puck in
10 min job
#2407
3 slide puck in
10 min job
3 slide puck in
10 min job
#2408
It's just an easy bump stop extension. Never done it myself with hockey pucks, but if you know what bumpstops are they can be extended from top or bottom. Since the pucks have been put in place, now upon compression the factory bumpstop will make contact with the axle, in this case 2 hockey pucks seated in the coil sooner, in turn stopping the coils from over compressing and stopping his tires from rubbing the fenders. This does not change height at all...
#2410
Have you guys tried Simple Green on your stained Plasti-dip grills? It worked great on mine, but the mud was only on there for a day or two...not months!
