Low-cost / Free mods that should be done?
#2942
Here's a small one to get back on track.
Pre-2007 all Wrangler tail lights had reverse lights on the upper side of the lenses. When the JK was designed some jackwagon decided to change the iconic tail light configurarion. On the JK you can simply remove and detatch and rotate them to follow traditional Jeep design.
Remove and unplug tail light assemblies. Take driver's side assembly and install "upside down" on passenger side, repeat process using passenger side lens ans installing on driver side. Double check light functions to ensure they are hooked up properly.
#2943
#2944
You're right! Did this mod and switched it back after I saw how it looked.
#2945
Sent from my SGH-T959 using Tapatalk 2
#2947
I do realize the housing isn't sealed. I wanted this to work for me, and I still might see if I can flip the lights in the housing somehow. I just thought I'd share my findings so others could be informed, and forgo the extra work if they also end up unhappy with the fit.
#2949
