Low-cost / Free mods that should be done?
#4241
Awesome on my way to HD
#4244
Drilled Out Door/Tailgate handles
I know this has been done but I just did mine. Used steel angle from Home Depot (stuff used to mount electric garage door openers) for the template. Make sure you put metal behind the handle so you don't scuff or drill through the door behind the handle. Don't forget to do the tailgate as well.
#4245
Another cheap mod.........purchased polypropylene rope (100ft) for $6 and used 24ft of it to make these two handles. Normally this technique is done using paracord, but its a little more expensive and you usually have to order it. I wanted to try it immediately, but couldn't find any paracord, so I tried the rope and it worked.
#4247
Drill a 7/16 hole into gopro case to allow constant charging. I also bought a 10' usb extension to use the camera on multiple mounts around the jeep while charging. Warning: camera case will no longer be waterproof!
#4248
You could also buy The Frame for it which has openings for all the ports. That way you can save your waterproof housing
#4249
