Lowe control arms= better ride????
Old Apr 22, 2015 | 03:37 AM
Baddkarmaracing's Avatar
I changed my lower control arms last night and I never expected to have any effects on the way the jeep rides but the first decent bump I hit (rr tracks) my gf and I both noticed that the jeep rides a lot better (did I mention it's a lot better?) now I am in no way complaining but I'm curious why they made a difference, any ideas?
Edit: Just noticed my typo in the title, should have said lower
Old Apr 22, 2015 | 04:59 AM
TheDirtman's Avatar
If you increased the caster when you installed the arms it would give your steering a much firmer feel, tracking better, and resisting bump steer. As far as ride quality it does not do anything.
Old Apr 22, 2015 | 05:45 AM
that's what I thought, but I swear it takes bumps better. I think maybe something was in a bind before.
I took it in for an alignment this morning because it was off before so I knew it would be way off after the new control arms, and now that the caster was adjusted properly the steering and tracking are much better, but I also noticed that it rubs at full lock and didn't do that before.
Old Apr 22, 2015 | 06:07 AM
Biginboca's Avatar
Some arms are bent for tire clearance like factory arms, some are bent for ground clearance like rock Krawler arms.
I like the synergy arms best cause they are bent for both types of clearance.
Old Apr 22, 2015 | 06:09 AM
now that you say that it makes sense, i forgot the factory arms were bent in for tire clearance.
Old Apr 22, 2015 | 07:22 AM
GoldenRubi's Avatar
Did you go to longer arms?
Old Apr 22, 2015 | 08:16 AM
just factory length RK adjustable arms. with the ability to adjust caster it made a lot of difference in the jeep, best thing I have done to it in a while.
Old Apr 22, 2015 | 08:29 AM
SpicedCrusher's Avatar
What size of lift?
Old Apr 22, 2015 | 08:50 AM
Originally Posted by SpicedCrusher
What size of lift?
2.5" netted closer to 3.5" though
Old Apr 22, 2015 | 10:34 AM
Yeah by increasing your caster after lifting will make it drive better and feel a little more stable however it will have no effect on how it handles bumps. Did you happen to get a spec sheet after your alignment? What's your caster at now?
