lower contol arms need help
Old Jul 2, 2009 | 03:39 PM
MOJEEP's Avatar
Default lower control arms need help
Hello everyone!!! This is my first post and I'm asking for help. I recently installed a skycrapper 4 inch lift and have since bought the Teraflex Adjustable Lower Control Arms. Teraflex says 24 inches on the Driver side and 24 1/8 on the Passenger. Does anyone have any suggestions on how to get the axle to move forward because as of right now the best I can get is 23 1/2 inches pulling with ratchet straps. I have tried jackin from the axle and with a cherry picker on the front Tow hook. Thanks in advance for any tips.
Old Jul 2, 2009 | 03:51 PM
Piginajeep's Avatar
did you try putting a jack under your Yoke to roll the axle into place?
Old Jul 2, 2009 | 04:02 PM
jkman77's Avatar
A pipe wrench on the axel tube work for me.
Old Jul 2, 2009 | 04:28 PM
TeraFlex's Avatar
Sponsoring Manufacturer
Start with 23.5" then go get it aligned.
Old Jul 2, 2009 | 04:34 PM
edwin907's Avatar
Stock is like 22.5" I believe, with factory upper arms I'd go about 23" to 23.25" and test drive it.
With stock upper arms the 23" number is almost always very close.
Old Jul 2, 2009 | 04:58 PM
mkjeep's Avatar
23 1/4 worked for me with a 4in superlift and it gave me 5in in the front. At 6degrees castor
Old Jul 2, 2009 | 07:20 PM
MOJEEP's Avatar
Thanks Guys!! I got it all lined up to teraflex specs. I just jacked up slightly on the pumpkin and it gave me the distance I needed. Rides much better and doesnt pull to the right anymore!!
Old Jul 2, 2009 | 07:23 PM
Piginajeep's Avatar
very good, that a nice trick to use adjusting your caster, you can basically roll the axle any direction easily
Old Jul 2, 2009 | 07:28 PM
09rubicon's Avatar
I am running at 23 3/8" on drivers side and 23 1/4" on the passenger side.....rides great!
Old Jul 3, 2009 | 02:21 PM
lee.moore's Avatar
Default ?
why did you need adj contol arm if you got the lift kit that come wth it so it be right?
