Lower control arm install help!!
Old Apr 29, 2016 | 12:25 PM
ikaros's Avatar
I purchased adjustable rock krawler lower control arms for the front and the instructions that came with are worthless. So if we say the control arms are shaped like a boomerang they install with the center tip up like the pic below correct? Assuming so but I don't want to do this over again. I called rock krawler but they did not call me back.
Also do the grease fitting face up or down?
2015 Hydro Blue JKU
Old Apr 29, 2016 | 12:52 PM
fredrok's Avatar
Pics is correct, fittings up or down but easier to access down.
Old Apr 29, 2016 | 02:07 PM
ikaros's Avatar
Thanks for the reply!
Rock krawler never called me back, I'm half tempted to return them and get teraflex
Old Apr 29, 2016 | 02:21 PM
BrowniesJK's Avatar
If you bought them for the front why is that a pic of the rear???
Old Apr 29, 2016 | 02:23 PM
ikaros's Avatar
It's just a pic I found online showing how they mount, was just using the pic as an example
2015 Hydro Blue JKU
Old Apr 30, 2016 | 07:19 AM
BrowniesJK's Avatar
10-4. I was a little concerned. I was also trying to figure out how you went longarm on only the lowers ;-)
Old Apr 30, 2016 | 08:32 AM
fredrok's Avatar
Probably a bit extreme. FWIW, I love my RK setup and have had a few bumps in the road but they've always taken care of me. Whenever I've called, I just go through the prompts and I've spoken to a helpful tech each time. If you PM RK here, you'll get answers as well.
