Lower Control arm length question
Old Feb 28, 2013 | 02:55 PM
nautique210's Avatar
Default Lower Control arm length question
Here is the situation. I have a 2013 JKUR that is scheduled to be delivered next week. Also I purchased a Teraflex 2.5" coil lift and fox shocks. Rims/ 295-70-17 tires. Etc. I have a pair of leftover Rough country fixed front lower control arms from their 3.5" lift that were used on my JKR for a short period of time. I believe the arms measure about 22 7/8". Would these arms be a good fit for my new unlimited? I realize they were designed for a completely different kit, but would it better than the stock arms?
Thanks
Old Feb 28, 2013 | 02:59 PM
k0260's Avatar
Thanks
Sure, the longer arms will give you more positive caster reducing flighty handling. I would try it, measure your caster angle once you have the new arms on. If you have 7+ caster, it will drive great, but can lead to drive line vibrations that can grenade your transfer case.
Old Feb 28, 2013 | 03:20 PM
I figured it's got to be better than stock arms. If anyone has a 2.5" lift, do you happen to remember the length of your arms?
Old Feb 28, 2013 | 04:20 PM
Slupe's Avatar
Rock Krawler 2.5 & 3.5 are to be set at 23 1/8
