Lower control arm squeak after lift please help
Old Jan 29, 2013 | 06:14 PM
Kirbdog44's Avatar
Default Lower control arm squeak after lift please help
I installed a teraflex coil lift and aev control arm drop brackets and after driving a while my driver side lower control has started squeaking a lot. They are the stock control arms so I don't think it's faulty bushings please help me fix this annoying problem!! Thanks!
Old Jan 29, 2013 | 07:13 PM
Kirbdog44's Avatar
Bump bump bump
Old Jan 29, 2013 | 08:18 PM
Jrenteria09's Avatar
Hmmm. I'd say take it off and lube the bushings. Reinstall and torque to spec.
Old Jan 29, 2013 | 08:35 PM
mistasparkl's Avatar
^^ x2. Also did you jump up and down on the bumpers and rock the vehicle w/ the control arms loosened before you torqued them down?
Old Jan 29, 2013 | 08:39 PM
Kirbdog44's Avatar
Yes I thought I did but maybe not on that side good enough, it's just the driver side too so I'm gonna try loosening then doin all that, any way I have over tightened or its too loose. My torque wrench only goes to 75 foot lbs so idk what 125lbs feels like.
Old Jan 30, 2013 | 05:53 AM
Kirbdog44's Avatar
Bump bump bump
Old Jan 30, 2013 | 12:53 PM
I would definitely go get a new torque wrench. You don't wanna mess up the torque settings on these suspension components.
