Lower Control Arms
I have a 2011 40dr with a Teraflex 2.5 lift. I was told I might want to put adjustable lower control arms on so that when I need to have the front end alignmnet done in the future, it would make it easier to do. Could someone please clarify this for me so I go the right direction.
I am about to install a 21/2 " lift on mine as well , so I talked to my frame and axle guy who I've know and trusted for years and asked him about it . He told me jk's have limited adjustments for camber and caster and adding a lift rolls the axle back at the top, as you go up in lift this gets worse, taking away adjustability , he told me to go with adjustable lowers to regain lost adjustability
before you go spending any money, you need to ask yourself if you are okay with the way your jeep rides. based on the fact that you already have this lift on and the fact that you're asking this question, i'm going to guess that you are fine with it and won't need to buy anything. the only reason why you should get adjustable lower control arms is because they will allow you or your alignment shop to add a bit more positive caster. this is something you would want IF you feel that your jeep is too flighty at highway speeds. with just 2.5" of lift, you should be fine without them.
also, please do NOT pay someone to do your alignment. with what you have, the most they they will be able to do is recenter your steering wheel.
My JK seems to run great, it's just that when I do need to get an alignment, I thought the control arm issue might save me some grief later. Just a question, but if I did purchase these, does on just remove the old arms and replace with the new ones, or is their adjustments etc., that have to be made? If so, I would rather take it and have them installed by someone who knows what the heck their doing, and that would not be me.
also, please do pay someone to do your alignment. with what you have, the most they they will be able to do is recenter your steering wheel.
if you really think you need an alignment, click on the link below and i think you will find that you can do this yourself:
http://project-jk.com/jeep-jk-write-...-end-alignment
Yeah I believe Wayolife meant "do NOT pay anyone to do an alignment"
Leave it alone! A Jeep is not the typical "car" that you are probably used to. An alignment for you in your current configuration would amount to adjusting toe in / out and steering wheel centering. Neither of which will require any additional parts to be added to your Jeep.
As Wayolife said unless your steering feels "flighty" or you decide to add more lift I would leave it be and enjoy your Jeep.
