Lower shock mount
Old Mar 18, 2009 | 06:52 PM
F5driver's Avatar
Default Lower shock mount
I ripped the lower shock mount off the passenger side front axle. It's pretty cheap metal. So I ordered a set of mounts from
Currie. I wonder how the control arm mounts will hold up?
Old Mar 18, 2009 | 11:30 PM
chuck45's Avatar
I was worried about the fron LCA mounts so I installed the ORE LCA gussets. The drivers side one on top of the pumkin is obviously ok but the other I worry about. I plan on bracing it and the track bar mounts when I do the axle sleeves. The metal Jeep uses for axle brackets is pretty soft.
