lube Locker?
Old Oct 6, 2009 | 02:35 PM
ckmehl's Avatar
Default lube Locker?
ok i see that david at Northridge is haveing a sale on diff covers. but what is a lube locker that he's selling in the sale? i've never herd of this.
Old Oct 6, 2009 | 02:37 PM
Robar's Avatar
It is a nice gasket that seals the covers instead of using RTV. You can ofter reuse them a couple of times.
http://www.northridge4x4.com/proddetail.php?prod=LL-D30
Old Oct 6, 2009 | 02:41 PM
wildandwillin's Avatar
Ive cut down my diff leaks by going to lube lockers. Saves money on changeing out diff fluid after every serious off road trip.
Old Oct 6, 2009 | 02:49 PM
AZOverland's Avatar
I don't see the sale on Northridges site do you need a promo code? Why does it save you money, you pull the cover everytime you change on oil?
Old Oct 6, 2009 | 03:06 PM
guinness's Avatar
Lube lockers are an alternative to using rtv sealent on your diffs.
I personally have had no problems w/ my lube lockers; however, I have had friends have poor results; as well as, great results. All in all they seem to be a crap shoot.
Old Oct 6, 2009 | 03:12 PM
AZOverland's Avatar
But why pull the cover every diff oil change? Maybe every 30-40K sure.
Old Oct 6, 2009 | 03:17 PM
Robar's Avatar
I don't. I got Lube Lockers when I peeled back my stock diff cover and hammered it back. I then reused the Lube Lockers when I later replaced my stock covers with some better ones.
Old Oct 6, 2009 | 03:26 PM
guinness's Avatar
I do it to see what is going o n in the inside. I know I can drain though the oem plug; however, i like to clean out anything that may have seeped in and check on the gears/ lockers.
Old Oct 6, 2009 | 04:40 PM
nangulator's Avatar
The lubelockers are great, no mess and re-usable, just get them.
Old Oct 6, 2009 | 05:22 PM
Rub61's Avatar
The lubelockers are great. If ya wack the cover on a rock you don't seem to generate and instant leak the way RTV seems to do. Much cleaner too with no gasket goop everywhere.
