Lube locker or just sealant?
Old Sep 29, 2013 | 01:45 PM
ibanez0154's Avatar
Default Lube locker or just sealant?
I am replacing my stock rear differential cover with a aftermarket one. I have read some guys just running sealant ( mind you stock this has twice wracked and leaked) just running the lubelocker gasket and lubelocker with sealant. Thoughts ?
Old Sep 29, 2013 | 01:46 PM
ibanez0154's Avatar
*thoughts on what route to go?
Old Sep 29, 2013 | 01:47 PM
sgtkersh's Avatar
Lubelocker. They are great. Easy to reuse, no sealant/RTV necessary. If you have the money just do it. Do it.
Sent from my iPad using Tapatalk HD
Old Sep 29, 2013 | 02:07 PM
JHP81's Avatar
rtv, readily available...
Old Sep 29, 2013 | 02:13 PM
Wrangled's Avatar
Personally I think the lube locker gives a bit more flexibility, in that if the cover ever shows a little seepage or leak, that you can simply snug up the bolts a bit. With the sealant, once it dries, it pretty much either seals or it doesn't. I suppose if it was put on thick enough you might have a bit of gap filling qualities. For me the ability to reuse was a factor as well.
Old Sep 29, 2013 | 02:56 PM
MMXJKU's Avatar
Lube Locker on the diff with RTV in the tool bag. The LL can be reused after routine inspection diff removals. It may also be reusable after diff cover damage on the trail. The LL is more forgiving than RTV if the diff cover take a hit. If the LL is damaged on the trail you have the RTV to get you home.
That's what I do.
Old Sep 29, 2013 | 06:13 PM
71T37's Avatar
I use RTV sealant called the Right stuff. It sticks to anything. I use it at work when working on Heavy Equipment and big rigs. Oil can be leaking out and it still seals (I have done it many times when you can not get it to stop weeping will putting a cover on).
Old Sep 29, 2013 | 06:30 PM
Maertz's Avatar
That's what I do.
i agree on this one. its also what i do. ive knocked my dif cover loose a few times on the trail and the lube locker barely leaked. Tightened it down and good to go. RTV may have been a different story.
Old Sep 29, 2013 | 06:31 PM
ibanez0154's Avatar
Looks like I'll be just doing the lubelocker and keeping the rtv in the trail tools. Thanks guys
Old Sep 29, 2013 | 07:18 PM
ibanez0154's Avatar
When filling it with fluid. How much do you put in?
